  3. How to automatedly close/select options of alert window...
  • Views 6026
How to automatedly close/select options of alert window in allegro system using Allegro .src or python scripts?
Yun777
Yun777 over 5 years ago
I'm currently working on an automation for modifying a original A.brd to another modified B.brd using .src scripts.
I would like to complete this modification without any manual settings. Therefore, I wrote a python program to run allegro.exe with .src scripts,
which will execute this command:
os.system(f'allegro.exe -product Allegro_performance -open {$originalbrd} -s {$scriptPath}')
where $originalbrd and $scriptPath are the paths of original A.brd and .src scripts for modification.
It can successfully run and complete a B.brd file.
However, due to the different allegro version between A.brd (version 16.6) and current allegro.exe version(17.2), after opening the original A.brd,
the system will prompt out a alert window(as below) to inform me the version difference and I must manually select "yes" to proceed.
Here're my question:
1. I wonder if there's a solution for using .src or python (os.system) script to stop from manually selecting "yes" on alert window ?
2. How to close Allegro program after the automated modification? Is there any SKILL script?
My environment as below:
OS: windows
Language: python 3.7
Allegro Version: 17.2
Thank you in advance !
  • DavidJHutchins
    DavidJHutchins over 5 years ago in reply to Yun777 +1
    For question 1 try adding set noconfirm at the beginning of your script...
  • Yun777
    ** update **
    I've got the solution for question 2. Just add "exit" in the last line of .scr file.
  • DavidJHutchins
    set noconfirm
  • Yun777
    Yun777 over 5 years ago in reply to DavidJHutchins
    thank you for the reply. It worked!
