  3. About allegro PCB impedance workflow manager vision
  • Subscribers 166
  • Views 13953
ichliebedich
ichliebedich over 5 years ago
Hi All!
I have curious of these things below
I set the impedance value like this (about 90 ohm) with CM Rule
but, when I ran the Analysis Workflow to see the impedance with vision
despite real impedance value is about 90ohm,the maximum calculated vision value was 53.64ohm incorrectly
Do I need to set something else?
regards.
  • oldmouldy
    oldmouldy over 5 years ago
    The Parasitics report assumes ideal planes; the Impedance Workflow uses the Sigrity based field solvers and handles non-ideal planes; you appear to have trace segments crossing voids in the plane Shapes so there won't be "a" value for the trace impedance.
  • redwire
    redwire over 5 years ago
    The 90 ohms comes from a differential "odd mode" impedance.  Single-ended uncoupled impedance would be 45 ohms each. The differential pair will double the value. I suspect you have a diff pair and each should be 45 ohms which is what is showing in the tool.
