  3. how to import the .mcm file on my board as an footprint...
  • Subscribers 168
  • Views 21102
how to import the .mcm file on my board as an footprint? (importing .mcm or .sip file to .brd file)
ichliebedich
ichliebedich over 5 years ago
Hi all,
I don't know well about between Allegro Package Designer and allegro PCB Designer file compatibility.
if someone create the bgm symbol with Allegro Package Designer, then the result file will be .mcm file or .sip file
as I know, To place the footprint, I have to have the .psm & .dra file (if I created by Allegro PCB Designer)
then if I want to place the package (footprint) with this .mcm file which I created by Allegro Package Designer on my board, How can I import the .mcm file on my board?
Is there any guide documentation about this?
best regard
  • Adolfo Hernan
    Adolfo Hernan over 5 years ago
    I am also searching for the same problem solution. I hope, I will find it soon.
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to Adolfo Hernan
    You can open .mcm file in pcb editor but with very limited features. In PCB Editor,  File - open - in drop down select all file and open .mcm file.
  • JaySashidh
    JaySashidh over 5 years ago
    Where you able to find an solution for the above issue?
