  3. Duplicate Values in list
  • Views 18442
vimaldevlpr
vimaldevlpr over 5 years ago
I want to get duplicate values present in list using skill programming.
A = ("A1" "A2" "A1" "BB1" "BB3" "A1" "BB1")
In this list I want to get repeated values
result = "A1" "BB1"
I used "!unique" Command shows me nil
Can anyone please guide me how to get
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    Try the ListDupes shown below:
    > pp ListDupes
    procedure(ListDupes(l)
    if(l
    if(member(car(l)
    cdr(l)
    cons(car(l)
    ListDupes(remove(car(l)
    cdr(l)
    cdr(l)
    nil
    > ListDupes( A )
    ("A1" "BB1")
  • vimaldevlpr
    vimaldevlpr over 5 years ago in reply to DavidJHutchins
    Hi David thanks for your reply..
    I don't know how to apply yours code in this categories can you guide me please..
    I have list of datas in list in that want to check only the "car(list)" duplicates in the list.
    Example:
    input file:
    inpswap.lst:
    116.14,AAA,AAA1
    116.14,BBB,BBB1
    130.14,AAA,AAA1
    218.07,DDD,DDD1
    112.1,DDD,DDD1
    218.07,EEE,EEE1
    116.14,FFF,FFF1
    code :
    procedure(swaplistkar()
     swapinp = infile("inpswap.lst")
     swaplst = nil
     swapdupnum = nil
     while(gets(swaplp swapinp)
       swaplp = car(parseString(swaplp "\n"))
      when(swaplp push(swaplp swaplst))
      close(swapinp)
     foreach(swploop swaplst
      swpparse = car(parseString(swploop ","))
      ; The code I want to find duplicates
    my output want to be:
    116.14,BBB,BBB1
    218.07,EEE,EEE1
    116.14,FFF,FFF1
  • luanvn81
    luanvn81 over 5 years ago in reply to vimaldevlpr
    Hi V !
    You can try this code, it's repaired from your code and base on your result.
    axlCmdRegister("swaplistkar" `swaplistkar)
    swaplst = nil
    swapdupnum = nil
    );end while
    close(swapinp)
    foreach(item swaplst
    if(length(setof(el swaplst cdr(parseString(el ",")) == cdr(parseString(item ",")))) == 1 then
    printf("%L\n", item)
    );end if
    );end foreach
    Luan.
  • vimaldevlpr
    vimaldevlpr over 5 years ago in reply to luanvn81
    Hi luan,
    Kindly thanks..
    In this case how to find Duplicates of " 2nd element in list"
    As like above case older we checked by 1 element in list now how to check 2nd element in list could you please tell me.
    sample input:
    116.14,AAA,AAA1
    117.14,BBB,BBB1
    130.14,AAA,AAA2
    218.07,DDD,DDD1
    112.1,DDD,DDD2
    219.07,EEE,EEE1
    114.14,FFF,FFF1
    output :
    130.14,AAA,AAA1
    112.1,DDD,DDD2
  • luanvn81
    Hi V!
    I think you can replace row code  if(.... then     by  if(length(setof(el swaplst nth(1 parseString(el ",")) == nth(1 parseString(item ",")))) > 1 then
    Luan.
