  3. Connect free via to GND plane
  • Views 14190
Nicolas S
Nicolas S over 5 years ago
Another easy one for you.
OrCAD PCB Designer Standard V17.4
I'm fussing with this for a moment now. I've found how to add a free via but no where to assign it to my GND net.
So, how do I assign the via to the GND net ?
Thanks everyone.
  • steve
    steve over 5 years ago
    So usually by invoking the Route - Connect command and a double click over a copper area will make the via the same net as the copper shape. You can also hover over the via, right click - Assign Net to Via and pick the net from the Options pane
  • Nicolas S
    Nicolas S over 5 years ago in reply to steve
    Steve,
    Thanks for this, I've been able to get it as I wanted ;)
    Regards.
