  3. Shows Unrouted net but no route is there
  • Views 12624
Sugreev
Sugreev over 5 years ago
I have an issue with the routing. It is showing me that there is one unrouted net but I check that there is no route on that pins.
It is showing that The IC GND pin should be routed to one of the LED GND pin. But I have similar LED's (connected in similar way), it is not showing for those.
I have circled the pins in the picture that it is showing it is unrouted net..
Can anyone help me with this ??
  • MaxS
    MaxS over 5 years ago
    Hi Sugreev,
    Where do you see that no unrouted nets and where you see that they are? It could be a schematic issue?
  • Sugreev
    Sugreev over 5 years ago in reply to MaxS
    I found my mistake.
    Thanks!
