  3. How to find traces that are not a 45 degree in layout?
  • Replies 9
  • Subscribers 166
  • Views 18466
MaxS
MaxS over 5 years ago
Does anybody know any method to find traces in the design that are routed at a free angle - not 45, not 90?
Looks like the Vision manager and Assembly rule checker cannot help.
  • masamasa
    masamasa over 5 years ago in reply to MaxS +1
    if u do not like manual operations, u would need to create a skill code like rfinley mentioned above. people in the pcb skill forum may help u.
  • RFinley
    RFinley over 5 years ago in reply to masamasa +1
    A text search through "Allegro SKILL reference 17.4-2019" is not showing how to access the angle of a CLINE Segment. I had similar problems trying to read the nets of a pin to pin DRC violation instance…
  • MaxS
    MaxS over 5 years ago in reply to masamasa
    Thank you masamsa for your reply.
    Your 1st proposal is an interesting one and it should work. The big disadvantage of that - it is manual...
    The 2nd unfortunately does not work in my case because I need to find traces that are connected to BGA circular pads. So I don't get DRC.
    And it's interesting that there is no 2nd DRC near BGA pad Thinking
  • masamasa
  • RFinley
    A text search through "Allegro SKILL reference 17.4-2019" is not showing how to access the angle of a CLINE Segment.   I had similar problems trying to read the nets of a pin to pin DRC violation instance.  Tech support bailed me out.
    Chapter 2 details the database structure inside Allegro.  CLINESEGS are a Figure database type that you would select in axlSetFindFilter.
    It looks like the two endpoint x,y's are easy to access.   If both X or both Y match, you can skip the trig... It's orthogonal.
    I would start with the excellent Find_DRC.il example as a framework.
  • MaxS
    MaxS over 5 years ago in reply to RFinley
    Okaay, interesting .... need to investigate.
    Thank you.
