  3. How to find traces that are not a 45 degree in layout?
  • Replies 9
  • Subscribers 166
  • Views 18465
MaxS
MaxS over 5 years ago
Does anybody know any method to find traces in the design that are routed at a free angle - not 45, not 90?
Looks like the Vision manager and Assembly rule checker cannot help.
  • masamasa
    masamasa over 5 years ago in reply to MaxS +1
    if u do not like manual operations, u would need to create a skill code like rfinley mentioned above. people in the pcb skill forum may help u.
  • RFinley
    RFinley over 5 years ago in reply to masamasa +1
    A text search through "Allegro SKILL reference 17.4-2019" is not showing how to access the angle of a CLINE Segment. I had similar problems trying to read the nets of a pin to pin DRC violation instance…
  • RFinley
    That one is a bit more obscure.   Curious what is driving this requirement?
  • MaxS
    MaxS over 5 years ago in reply to RFinley
    Some of the traces in the layout were routed at free-angle or edited by vertex command. Need to return them back to 45 degree style. It's a manufacturer requirement.
  • RFinley
    RFinley over 5 years ago in reply to MaxS
    Unless your airgap minimum is less than 0.07mm or less,  I would question that.   It's a chemical process, etching the copper.   For a conductor, it's never going to come out perfect unless you use MCM or chip lithography etching methods and unusually thin copper in the stackup.
    I think a skill script can be written to flag any trace segment that isn't orthogonal.  The trigonometry is straightforward and you have a full set of Trig functions in SKILL.
  • masamasa
    u can find traces that r not a 45 degree angle.
    first, u select "cline segs" in the find filter.
    then u select clines and run the "show element" command.
    u will see the element of each cline and the angle of each cline.
    an example is shown below.
    the middle cline has a 20.905 degree angle but others have a 45 degree angle.
    u can place them in the excel sheet and sort them out to find angles that are not a 45 degree.
    u can also set up the design level drc by using the analysis mode on setup --> constraints --> modes
  • masamasa
    please look at the article as well.
    https://www.flowcad.ch/fr/newsarea/blog-why-move-up-to-orcad-allegro-17-2-2016-new-design-level-checks.html
