  3. How can I align my diodes horizontally in equal distance...
  • Views 13618
How can I align my diodes horizontally in equal distance?
frank673
frank673 over 5 years ago
Hello, I am using PCB Editor 17.4.
I would like to align diodes horizontally at 5 mm apart. There was an option called "align component" in older version of PCB Editor. I can not find a similar option in 17.4.
Any advice to do the alignment would be appreciated
  • redwire
    redwire over 5 years ago +1
    Still there in 17.4 Just be sure you are in placement edit. Select parts, right mouse, align components
  • redwire
  • frank673
    frank673 over 5 years ago in reply to redwire
    It worked, Thank you. I was missing the placement edit.
