  3. How to add symmetric ground reference via in PCB editor...
  • Views 14418
How to add symmetric ground reference via in PCB editor 17.4?
frank673
frank673 over 5 years ago
My intention is to add reference ground return via for PCIe3 signal. The following image is the one I have added and it is not symmetric. The other image is the reference board layout, it is how my desired out should be.
Any advice on how to update my layout?
My non-symmetric layout:
Desired output in the reference design:
  • RFinley
    RFinley over 5 years ago +2
    Dr. Bruce Archambeault wrote a paper for the IEEE: "Via Asymmetry Causes Common Mode Conversion from Differential Mode Signals" Importance of symmetry of ground vias to minimize common-mode EMI problems…
  • RFinley
    Forgive me as I don't get to work with PCI-E.
    But, from an RF standpoint, splitting a diff pair is never a good idea, regardless of bit rate.   You lose common-mode noise rejection, impacting BER, when your coupling spacing is spread like that.
    Sometimes, we have ground pour "peninsulas" that stick out that need to be "tacked down" with extra vias.   I can't think of a benifit of that via.
    And, adding gnd vias close to the device increases risk of impedance discontinuity from your signal nets to any ground via.
    Is your signal to ground spacing trace to via pad about 1.5 to 2x your dielectric thickness to layer 2?
  • frank673
    frank673 over 5 years ago in reply to RFinley
    Ground via is used for a return reference for PCIe signal vias. It is advised to have 2 ground vias and due to space constraints, I am adding only one via.
  • RFinley
    RFinley over 5 years ago in reply to frank673
    I forgot about the multiple ground plane problem if you are jumping from front to back.   I.E. need to stitch the ground reference planes together around the transition.
    Do you have the high-speed rules license option?  It automates this problem.
    We have to avoid causing an increase in self-heating of the board with an impedance mismatch.  To minimize insertion loss, my coworkers design an impedance-controlled transition:  a signal via plus up to four ground stitching vias then validate it using Microwave Workbench.
    We drive repeatability by building a library of thru-hole component for the correct via arrangement for a stackup and add these parts to the schematic.
    It's very low tech but we don't use other features of the Allegro PA-3100 high-speed option to justify that option license (costs more than base Allegro.)
  • frank673
    I have fixed the problem using the "slide" option by selecting the via and the entire line segment of the differential signal. The suggestion of using a thru-hole component seems interesting. I think I have to create a footprint with the via structure. I wish I could add more ground vias, but four ground via is an ideal situation when the board becomes dense.
  • RFinley
    Importance of symmetry of ground vias to minimize common-mode EMI problems.
    Dror Haviv wrote a SignalIntegrityJournal article that show the improvement of multiple stitching vias.
    "How to stop your differential vias from leaking"
    I think you will have fewer problems with stitching around the pairs, not splitting the pair.
    • Vote Up +2 Vote Down
