  3. XSECTION
  • Subscribers 168
  • Views 15779
XSECTION
mir0mik
mir0mik over 5 years ago
Hi guys,
Can someone think of a solution how:
- from a custom SKILL form window open XSECTION - axlShell( "section")
- then block the custom SKILL form window from inputs - xsection is blocking command for PCB Editor, however if the SKILL code is not registered through axlCmdRegister(...) it wont be blocked
- detect that xsection is open
- detect that xsecition is closed
What I'm trying to do is - in my custom SKILL form the user can see what is the current xsection thickness, he/she can click on a button that will run xsection and when the xsection window has been closed the value in the custom form is automatically updated. I have an issue with the bold part...
Miro
  • B Bruekers
    B Bruekers over 5 years ago
    axlXSectionGet("PRIMARY" 'thickness) returns the stack thickness.
  • mir0mik
    mir0mik over 5 years ago in reply to B Bruekers
    Hi B Brukers,
    Thanks.
    Yes, I know this command, it works well. However, the issue for me is to detect that the cross-section was changed by the user meanwhile my SKILL code was running - in other words, I need to know when is the "right" time to call the axlXSectionGet("PRIMARY" 'thickness)... Any idea how to achieve this (except manual or periodical refresh)?
    Thanks!
    Miro
  • CC20250910538
    CC20250910538 over 1 year ago
    eggy car
    mir0mik said:
    Hi guys,
    Miro
    You need to wrap the axlShell("section") call inside a function registered with axlCmdRegister, e.g., "myXSectionHandler". This way, the command will block until the XSECTION window is closed, and you can safely update your form afterward. Without registering, axlShell runs asynchronously and won't block.
