  3. The right way to go with Place Replicate
  • Views 14675
Fredda
Fredda over 5 years ago
What is the "right way" to go with Place Replicate? Is there a preferred workflow when using Place Replicate?
I've only seen tutorials/videos on how to use them in the PCB Editor, but it seems more logical to define a Replicate Module in the schematics instead of clicking and selecting symbols in the PCB editor. Can that be done?
Also, how can I view existing Replicate Modules? I get the below message when trying to create a place replicate module. Is there an editor where I can edit existing modules?
  • Wild
    Wild over 5 years ago
    I posted 2 pdfs below, I had to break it into 2 parts due to the upload size restrictions.  I hope this helps.
    I prefer creating a modular design based on the schematic, been doing design work that way for over 10 years.  However it is not an easy process the first time you do it.
  • Wild
    Wild over 5 years ago in reply to Wild
    0066.Hierarchical Design Example for Design Reuse Part1.pdf
  • Wild
    5658.Hierarchical Design Example for Design Reuse P2.pdf
  • Fredda
    Fredda over 5 years ago in reply to Wild
    Thanks. I'll have a look at them.
  • Fredda
    That seems to be a good way to go if you're doing a lot of designs that are using the same type of modules. Thanks for sharing. As I understand it doesn't involve the Place Replicate commands at all. I might try it for the next design!
    However, I still want to know and understand more about the Place Replicate commands!
