  3. Set different width for same trace
  • Subscribers 166
  • Views 12900
Sugreev
Sugreev over 5 years ago
I want to connect Data pins of the IC to the data pins of the USB and want the width of that trace to be 15mils. But problem is IC  and USB  pins can connect only 10 mil trace width otherwise it gives error.
Can we change the width of the trace in between ? If yes, can anyone please help me how to do that ??
  • excellon1
    excellon1 over 5 years ago
    So the first thing to figure out is "What is the Drc & what does it say" ?
    Can you post a screen shot.
    All the best.
  • redwire
    redwire over 5 years ago
    Yes you can.  Each net can have a standard width and a "neck" width.  You can set the neck width in the constraint manager.  When you route, click on the pin and start to route, then right mouse and choose "neck".  The rules you applied will be in force until you choose to return back to normal.  Check youtube for helpful videos.
