  3. How to control "Same net spacing" constraint rule value...
  • Replies 10
  • Views 8463
How to control "Same net spacing" constraint rule value of overlap rate?
ichliebedich
ichliebedich over 5 years ago
Hi All
If I actvate the same net spacing rule at the analysis mode, the same nets between Via and Shape keep the distance per overlap rate.
as I know from the test, the via only applied the rule with same net shape under 50% overlap rate.
but I want to keep short net the via with shape even under 30%. (see below)
of course it is working without activating same net spacing rule, but I have to keep on the rule..
how can I control the rate value of this?
regard
  • Lock2002
    Lock2002 over 5 years ago
    It uses the exact center of the via or pin. once you cross that it either voids or floods. So you're stuck with 50%
  • ichliebedich
    ichliebedich over 5 years ago in reply to Lock2002
    doesn't it have any function to control the percentage? or is there other alternative way?
  • jc teyssier
    jc teyssier over 5 years ago in reply to ichliebedich
    I do not think so: it is not a percentage: if the shape reach the via origin (even if not centered i gues, make no sense in this case)  then it will be connected. If not reaching, it is voided.
    What you have to do is to modify shape boudary to englobe the via (at least via origin)
  • ichliebedich
    ichliebedich over 5 years ago in reply to jc teyssier
    thank you I haven't notice that mechanism !  I found alternative way which modify the shape to cover the orgin like below
  • jc teyssier
    Be aware that you obtain smalls acid traps at via/shape intersection now.
