  3. is it possible to generate ISCF format netlist from .brd...
  • Subscribers 166
  • Views 13778
is it possible to generate ISCF format netlist from .brd file
PavithraC
PavithraC over 5 years ago
I have only the pcb board file with me. Is it possible to generate ISCF format netlist from .brd file.
If yes, please provide steps.
I hope I can get someone‘s help, thanks.
  • steve
    steve over 5 years ago
    Unfortunately you can only export this from the schematic (OrCAD Capture).
  • PavithraC
    PavithraC over 5 years ago in reply to steve
  • luvishis
    luvishis over 5 years ago
    Hi
    That can be possible. Elgris Technologies (www.elgris.com) can do it, but the ISCF will not be same as ISCF extracted from schematic used to create the board.
     It is necessary to generate schematic from a board and then save it to OrCAD.
     From OrCAD  it is possible to extract ISCF
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I just tested this process by generating an EDIF netlist from Allegro (using some custom skill code I wrote for a customer a few years ago)
    then imported the EDIF into Capture, then generated the ISCF netlist
