  3. Method for identifying Dummy Nets in PCB Editor?
  • Subscribers 162
  • Views 16086
Gipper
Gipper over 4 years ago
This question relates to OrCAD PCB Designer Pro 17.4 S016.
I recently had to make several schematic changes to a very busy board. Is there a quick or simple method to identify all the unassigned, or Dummy, nets on a project?
  • RFinley
    RFinley over 4 years ago
    There's a skill script on support.cadence.com called "dh_dummy_net.il"
    Or, you can use the find filter in layout.
    >Display >Assign Color
    Options Tab
    Select a color
    Under Find Filter tab, you have to make sure Nets are selected.
    Then use  Find By Name
    >Net
    > dummy
    press  the tab key.
  • Gipper
    Gipper over 4 years ago in reply to RFinley
    Perfect. I originally looked for "Dummy" under Color Dialog->Nets, but I didn't see it.
    The above worked!
  • RFinley
    RFinley over 4 years ago in reply to Gipper
    yeah, weird how the nets are named "dummy".
  • redwire
    redwire over 4 years ago
    Allegro has always let you highlight (aka "assign color") a net called "dummy".  Just use the find box and type in "dummy" without quotes instead of a net name.  It won't show up in the list of nets. No need to play around with the color box or skill.  Same thing works for de-highlight.
  • CadAce2K
    CadAce2K over 4 years ago
    I still do it the old fashion way - Display Highlight;  Pick a color (I normally use dark grey); In elements - select Nets in find; and type   dummy   in the fillin block. They now turn on as Dark Grey.
