  3. Issue with impedance matching of differential pair
  • Replies 17
  • Subscribers 166
  • Views 27343
Sugreev
Sugreev over 5 years ago
I am designing a PCB and having issue with the impedance matching of the differential pair. I am using the guidelines of the IC manufacture to design my PCB. Here is the link of:
https://www.ftdichip.com/Support/Documents/AppNotes/AN_146_USB_Hardware_Design_Guidelines_for_FTDI_ICs.pdf
According to this guidelines, the differential pair (DP and DM signals of the USB) must have 90 ohm impedance to each other. But I am not able to match this impedance. I tried using different line width (10mils,15mils,20mils,25mils,30mils) of the differential pair but it doesn’t help me. Also, I tried using 0 ohm resistor in between that didn’t help as well.
The specifications of my PCB are- the conductor thickness is 2oz(2.8mils) and the dielectric thickness is 63 mils (using FR-4 and dielectric constant is 4.5).
Can anyone please help me in resolving this issue ??
  • excellon1
    excellon1 over 5 years ago in reply to redwire
    Sugreev. My design did not use the impedance calculator in the cadence tool but was done on a RF Simulator.
    So the first thing is you have to have manageable trace widths so as to route off the connector and to the IC you are using. I recalculated my initial design which had a trace width of 24 mils down to 13 mils so it would be easier to handle this. As Wild pointed out the impedance calculator in Allegro does not handle CPWG so don't worry about it.
    For a DIFF Impedance target of 90 Ohms there are various combinations of trace to space and side wall ground that can be used.
    On a pcb design most PCB tools use a "Global Impedance Calculation" Based on the stackup only. This has a huge caveat in a fair few regards.
    Anyway to get to where you need to be the first thing is you want to remove the constraint for the impedance from the Allegro Spreadsheet.
    Create a diff pair that has a trace width of 13 mils and a gap of 6 mils and route it in on the top layer.
    Next add the ground either side of that diff pair. The spacing to the diff pair is 6mils. Just like in the picture above.
    You can increase the spacing of the Ground Side wall to 10 mils. This will reduce the returnloss of the diff par a little but might make the design easier to manufacture.
    Here is a pic of the Net Rules for the diff pair.
    Before you add in the ground you want to set in the spreadsheet Your Line to Shape clearance and make it 6mils or 10 mils as explained above. This is done under the spacing > spacing constraint set - Shape to line setting.
    In your picture it looks like you are just going a very short distance so things are less critical from the perspective of line signaling. If the 13 mil trace for the diff pair is too wide to come off the pins then go with
    Trace width = 10 Mil
    Trace Space =  6Mil
    Trace to ground space = 6mil.
    Update your constraints to accommodate the design spacing etc.
    All the best.
  • redwire
    redwire over 5 years ago in reply to Sugreev
    Any chance you can post a zip of your board?  I also do as excellon says which means I use physical construction.  And, depending on how critical the impedance measurement needs to be I might have my fabricator do their own calculation to see what their final impedance value will be.  That's not really necessary for this design however.
    I see that your "target" impedance is set to 90 and Cadence thinks it's 178(in the DRC).  That is telling me that Allegro is calculating with the wrong reference to the signal.
  • excellon1
    Red this is very curious. In 16.6 the stack up manager agrees fairly closely to the RF-Sim though it is off by 7 ohms or so. Not a big deal. By default that stackup manager assigns a dialectic constant to the conductor. Seems odd to do this but fudging that value of 4.5 to 8 brings the diff line impedance in line with the rf sim. Last I checked the dialectic constant of copper was infinity. Slight smile
    Plugging in a mask layer above reduces the impedance too.
    Ignoring the CPWG for the moment and just going with std edge coupled lines  Cadence reports 103.34 Z for the diff pair using a trace width of 10Mil and space of 6mil.
    When DRC reports your error is it reporting on the single line impedance or the actual calculated diff pair impedance ?. 178 divided by 2 = 89 which is very close to 90 ohms, assuming similar to what I have in the stackup.
    I live more in the world of the physical than the CM for certain things but initially I got DRC errors too. My line impedance reported by the drc was based on the single line impedance. I had to plug in the single line impedance and not the actual required Diff-Pair impedance to make the drc go away. The DRC looks to report only single line impedance not the actual Diff-Pair as one would think if analysis mode is enabled for impedance.
    Note the single line impedance matches the spreadsheet and all is good.
    While I typically don't use the Stack up manager for impedance control for certain things it looks to me that while it can provide diff-pair info the DRC is all based on just the single line impedance only.
    Maybe you can confirm that to be the case as a sanity check.
    Thanks.
  • redwire
    redwire over 5 years ago in reply to excellon1
    Hi excellon, I get the same results as you.  I was kind of hinting at the fact it was only single-ended based on the 90/180.  And now, from what I can see it appears that the impedance rule really only applies to the single-ended variant and CM does not understand a diff-pair impedance.
    So...as you said earlier.  Stick with the physical rule definition... let's see if the OP has any more questions on that.
  • Sugreev
    Sugreev over 5 years ago in reply to redwire
    Thank you Excellon and Redwire!
    From all this what you have explained, I think that I have made mistake in setting the impedance of diff pair to 90 ohms in constraint manager.
    In picture below, I have set the single-line impedance of the diff pair C-set to 90 ohms  in the electrical constraints.
    How much value should I set to the single-line impedance ?
