  3. Via not showing up on menu/options
  • Subscribers 160
  • Views 4354
daxdax
daxdax over 4 years ago
I don't have any option to add or specify via. Allegro 17.2.
  • excellon1
    excellon1 over 4 years ago
    Maybe try go to "Physical Constraint Set" tab all layers.
    Click in the via cell to add vias.
    All the best.
  • daxdax
    daxdax over 4 years ago in reply to excellon1
    You were right, that's how I was able to do it, but only in 16.6, where the brd file was natively made. Once upreved to 17.2 I was not able to recover that option.
  • CadAce2K
    CadAce2K over 4 years ago in reply to daxdax
    I've never had that issue between revs, but might I suggest checking you PADPATH and make sure your design can find the vias? But that option has always worked for me. If you can see them in Constraints Manager/Physical you should be able to add them during connect as long as your layers are shown correctly according to the via padstack.
  • CadAce2K
    CadAce2K over 4 years ago in reply to CadAce2K
    I'm currently on 17.4
