  3. Thermals in smd pin, large pad on top but only via pads...
  • Views 12395
Thermals in smd pin, large pad on top but only via pads on bottom
atoddrich
atoddrich over 5 years ago
In pad editor can you add vias into a  large pad that is going under an IC but only have the large smd pad on top and only via pads on bottom?
In pad editor I create a "thru-pin" pad stack with the large pad on the top design layer.
Which is fine but I don't want a large pad on bottom, only the via pads.
  • CadAce2K
    CadAce2K over 5 years ago
    Make the large pad a SMD pad so it's only on one side. The vias still connect to it, but there's no pad on the bottom side.
  • atoddrich
    atoddrich over 5 years ago in reply to CadAce2K
    Will this affect the barrel?
  • CadAce2K
    CadAce2K over 5 years ago in reply to atoddrich
    no
