  3. Why is a crosstalk table needed for a basic fast autoro...
  • Views 15879
Why is a crosstalk table needed for a basic fast autoroute
tmd63
tmd63 over 5 years ago
When attempting to use the autoroute feature in Allegro PCB Editor (design.brd not design.dsn file). The router refuses to run unless a cross-talk simulation is run first.
I just want a simple x-y autoroute done using specific layers where layer 8 is the x direction and layer 10 is the Y direction (for example). I have over 4,000 connections to complete in 4 hours and it is too much for my mouse/fingers/brain to do manually. But the simulation is taking forever to run and will provide no useful help as there are no impedance requirements on the PCB!
So how can I run a simple Autoroute to remove the majority of the simple connections (I have already fanned out most of the connections manually)? Or does Allegro not allow for autorouting any more?
  • redwire
    redwire over 5 years ago in reply to tmd63
    The BRD gets converted to DSN for the autorouter.  You can do it manually (File->Export...etc) or when you invoke the autorouter it generates the Specctra format DSN file from your BRD.
    Sounds like you might need to tune up your autorouter knowledge before pushing go?
