  3. How to Upgrade and DB doctor for all 1500 parts of PCB footprints...
  • Replies 10
  • Subscribers 166
  • Views 21995
How to Upgrade and DB doctor for all 1500 parts of PCB footprints from 16.2 to 17.2
Raamvishnuraja
Raamvishnuraja over 5 years ago
Hi Guys, I have my library folder contains 1500 parts of PCB footprints which was created in 16.2 and I need to upgrade and DB doctored all parts to 17.2.
Please let me know the procedures.
Thanks and Regards
Raam.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    The uprev command has the -b option which allows multiple files and/or directories
    The documentation explains the various options...
  • Raamvishnuraja
    Raamvishnuraja over 5 years ago in reply to DavidJHutchins
    Hi David, thanks for immediate response,
    Could you please explain more about procedure like where I can find the "uprev" option or do I need to enter on "command window"
  • DavidJHutchins
    DavidJHutchins over 5 years ago in reply to Raamvishnuraja
    Uprev is an external stand-alone command that you run from a "command window
    I just noticed in 17.x it has been renamed to 'allegro_uprev'
    for example I just created the folder c:\temp\symbols & dumped the libraries from a design into it,
    then ran:
    C:\Temp\symbolh> allegro_uprev -b
    it ran dbdoctor on every file in the folder & generated uprev.log, below is the bottom of that file:
    C:\Temp\symbols>tail -20 uprev.log
    _28mmx_85mm.pad success.
    _2mmx_8mm.pad success.
    _4mmx_9mm.pad success.
    2: Descending directory: [ signoise.run ]
    3: Descending directory: [ case1 ]
    3: returning
    2: returning
    1: returning
    SUMMARY UPREV RESULTS:
    Successful uprevs: 436
    Failures: 0
    Warnings: 0
    Directories Procesed: 4
    Hit directory limit ( 3) times: 0
    End Time: Fri Jun 18 09:33:37 2021
    C:\Temp\symbols>
  • Raamvishnuraja
    I ran command D:\Raam\Raam_LIB\Allegro> allegro_uprev -b. it did not worked
    then I found the "allegro_uprev.exe" at C:\Cadence\SPB_17.2\tools\bin and copied it to my library D:\Raam\Raam_LIB\Allegro. then ran the exe file from library folder. still did not worked
    then I entered command to run D:\Raam\Raam_LIB\Allegro\allegro_uprev.exe still not working.
  • Nilanjan Talukder
    Nilanjan Talukder over 2 years ago in reply to Raamvishnuraja
    Go to  D:\Raam\Raam_LIB\Allegro> and run allegro_uprev.exe -b and that should do it.
