  3. Place pin around circle
  • Subscribers 167
  • Views 13988
LSAUGE
LSAUGE over 5 years ago
It's been some time that I look for a feature that would be useful for me and that I didn't saw in the tutorials.
Is it possible in PCB Editor 17.4 to place a pin arround a circle (the circle is only for the design and will not be in the pcb) at a particular angle (see picture below) ? I know that I can place a pin at particular coordinates but I'd rather not calculate the exacts coordinates arount the circle if there is an easier way..
Thanks a lot,
Loïc
  • jc teyssier
    jc teyssier over 5 years ago
    Draw the lines and the circle on a temporary layer then you will be able to snap to intersections to place pins (when placing pin, rigth clic: snap options are located here)
  • atoddrich
    atoddrich over 5 years ago
    I placed a circle where I wanted center to be then place another circle around the center.
    Copy a via then snap to the outer circle by segment vertex.
    Then Edit>Copy, Options>Polar select the via you placed on the vertex then snap to the center circle.
    This will allow you to place multiple copies around the outer circle.
    There is probably a better way.
  • RFinley
    RFinley over 5 years ago
    Allegro Productivity toolbox has a polar grid function.
    www.youtube.com/watch
  • LSAUGE
    Thank you all for your answers !
