  3. generate reports which have two more other properties with...
  • Views 11545
generate reports which have two more other properties with text edior
ichliebedich
ichliebedich over 5 years ago
Hi All
How to generate report which include two more properties with text editor?
I refer to this "">community.cadence.com/.../extracting-layout-data"
and I follow the the sample code but It was not work well
report only import the first parameter before END
regards
  • oldmouldy
    oldmouldy over 5 years ago
    I would say the the report example in this blog is incorrect since it combines two report templates that both use the NET domain, either section will work alone but using this combined example only results in the first section of the Template being used. You could swap the report template sections to prove that.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    Since you are extracting multiple views you need to denote separate output files for view...
    Below is an example:
    C:\Temp>extracta BeagleBone_Black_RevB6_nologo.brd diff_pair.txt diff1.dat diff2.dat
    Revising design for compatibility with current software.
    Extract started ... command file is 'diff_pair.txt'.
    Extract ended.
    C:\Temp>head diff1.dat
    A!DIFF_PAIR_GRP_NAME!
    J!C:/Temp/BeagleBone_Black_RevB6_nologo.brd!Fri Jun 25 07:35:42 2021!-14719.90!-10447.10!21280.10!13552.90!0.01!mils!BEAGLEBONEBLK_A6A!62.000000 mil!6!OUT OF DATE!
    S!HDMI_TXC!
    S!HDMI_TXC!
    S!HDMI_TX0!
    S!HDMI_TX0!
    S!HDMI_TX1!
    S!HDMI_TX1!
    S!HDMI_TX2!
    S!HDMI_TX2!
    C:\Temp>head diff2.dat
    A!NET_NAME!DIFF_PAIR_GRP_NAME!
    S!N22488252!!
    S!USB1_PWR!!
    S!N22420447!!
    S!N22420444!!
    S!N22420400!!
    S!VBUS!!
    S!VDDS!!
    S!VIO!!
    However this can be reduced to 1 file as shown below:
    C:\Temp>type diff_pair1.txt
    NET
    DIFF_PAIR_GRP_NAME != ""
    DIFF_PAIR_GRP_NAME
    NET_NAME
    END
    C:\Temp>extracta BeagleBone_Black_RevB6_nologo.brd diff_pair1.txt diff3.dat
    Extract started ... command file is 'diff_pair1.txt'.
    Extract ended.
    C:\Temp>head diff3.dat
    A!DIFF_PAIR_GRP_NAME!NET_NAME!
    J!C:/Temp/BeagleBone_Black_RevB6_nologo.brd!Fri Jun 25 07:37:10 2021!-14719.90!-10447.10!21280.10!13552.90!0.01!mils!BEAGLEBONEBLK_A6A!62.000000 mil!6!OUT OF DATE!
    S!HDMI_TXC!HDMI_TXC-!
    S!HDMI_TXC!HDMI_TXC+!
    S!HDMI_TX0!HDMI_TX0+!
    S!HDMI_TX0!HDMI_TX0-!
    S!HDMI_TX1!HDMI_TX1+!
    S!HDMI_TX1!HDMI_TX1-!
    S!HDMI_TX2!HDMI_TX2+!
    S!HDMI_TX2!HDMI_TX2-!
    C:\Temp>
