  3. Remove designated pad's thermal relief void to copper p...
  • Views 3229
Remove designated pad's thermal relief void to copper plane
AName
AName over 5 years ago
In OrCAD PCB editor (version 17+), how to remove designated component pad's thermal relief void to the copper plane, so the pad will have a direct connection to the plane?
This should be done only to specific designated pads, while the other pads in the design should keep their original thermal relief behavior.
  • excellon1
    excellon1 over 5 years ago +2
    Sure thing. This can be done on a pin by pin basis. In the find filter check pin. Right click on the pin you wish to edit and choose "Property edit" In the list click on " DYN_THERMAL_CON_TYPE "…
  • AName
    AName over 5 years ago in reply to excellon1 +1
    It works. Thanks!
  • excellon1
    DYN_THERMAL_CON_TYPE " and give it a value of "Full Contact"
    Give that a try and see if it works .
    Note this assumes your copper pour is dynamic.
    • Vote Up +2 Vote Down
  • AName
    It works. Thanks!
