  3. Pin numbering
  • Replies 7
  • Subscribers 166
  • Views 16221
Pin numbering
LSAUGE
LSAUGE over 5 years ago
Sorry, I have the impression that I ask a lot of questions these days. ^^'
I have two questions concerning pin numbering :
1) In a package symbol, I have two mechanical holes. These mechanical holes have a pin number. Is it mandatory to have a pin number for mechanical holes ? It's just a hole for guiding the plastic part of the component and I don't want to have a pin for these holes in the schematic in Capture.
2) Is it mandatory to have the same number of pins on the schemtic than on the footprint ? The reason is that I have a schematic that have a lot of relays. For readability purposes, I draw the relay symbol as a simple switch with two pins but in fact the footprint has 4 pins (2 pins for the coil of course). Do I have to have 4 pins in my schematic or is there a workaround ?
Thanks a lot in advance
Loïc
  • jc teyssier
    jc teyssier over 5 years ago in reply to Wild
    Physical set are for copper witdth, layer allowed or not and so on: not for spacing purpose. Spacing matrix is only in sacing sets.
    i doubt you can assign a spaing type to a pin: it is linked to nets.. No pin number => no net can be siigned => no spacing type can be assigned.
    This is why we treat mechanical pins as eletrical one with a pin number..
  • Wild
    Wild over 5 years ago in reply to jc teyssier
    Sorry for the Typo (not enough coffee), I meant the SCS (Spacing Constraint Set) Disappointed, once again there are spacing rules for hole to line, pin, via, shape and hole.  I have attached a screen shot from my 16.6 Rev of a mechanical slot with the properties options shown.  Would this not also work?
    5KV creepage hole.
