  3. Allegro - Export - PDF - How to make objects like clines...
  • Views 4181
Allegro - Export - PDF - How to make objects like clines, pads, and vias looks opaque/solid in PDF viewer
VKPA
VKPA over 5 years ago
Exported pdf file from Allegro - OrCAD 17.4
Expected PDF file something like this (I have used GC-Prevue Gerber viewer tool)
  • steve
    steve over 5 years ago +1
    Try Setup - User Preferences - Interfaces - PDF and change the pdf_filled_shape_transparency to 0.01
  • steve
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to steve
    User preferences - sometimes a magical box. Many things can be done by setting up some parameters. Is there any document which details each of the parameters with an example?
  • steve
    steve over 5 years ago in reply to AvengerThanos
    Try the Info button in the User Preferences form. This should give you an idea what each variable does.
  • VKPA
    VKPA over 5 years ago in reply to steve
    Thanks Steve! I got what I was looking for
