  3. Plus/Minus Column Not Visible in CM
  • Subscribers 166
  • Views 2630
ameehan2
ameehan2 over 5 years ago
Under Electrical/Net/Relative Prop Delay, the +/- column remains blank no matter what I do. Another designer who looks at the same .brd on his system can see that column. Any ideas of how to fix? I've tried 'Analyze', double clicking at the top and in the boxes with no luck. Any advice would be appreciated.
  • steve
    steve over 5 years ago
    If it works on another PC it could be related to the actual version of software you are running. Make sure that you get the latest hotfix for 17.4-2019 S019 from Download Manager / Cadence support site then try again.
  • ameehan2
    ameehan2 over 5 years ago in reply to steve
    Thanks Steve, I wasn't aware of the new hotfix. I'll try it out.
    I tried it out on both my workstation and my laptop with the new hotfix and still getting the same results - no pluses or minuses visible in that column. Is there some setting that I need to look at?
    Thanks.
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to ameehan2
    Did you perform - analyze on the matched group ?. If not then try once.
  • ameehan2
    ameehan2 over 5 years ago in reply to AvengerThanos
    Yes, a co-worker finally pointed that out to me and that fixed the problem.
