  3. Measurement function in Allegro Free Physical Viewer
  • Views 36581
Jojoaction
Jojoaction over 5 years ago
Hi, I'm using Allegro Free Pysical Viewer to check a .brd design file.
Is there a function to measure distances?
The X and Y Axis value is shown at bottom bar with absolute and relative setting, but it is much afford for diagonal measurements to calculate distances.
BR Johannes
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    If you are using the new (IMHO brain-dead) 17.4 free viewer, use View>Command & then type in 'show measure'
    If you are using allegro_free_viewer_classic then it's available as Display>Measure & a toolbar button
  • Jojoaction
    Jojoaction over 5 years ago in reply to DavidJHutchins
    Works well! Thanks a lot.
