  3. Rotate PCB Layout
  • Subscribers 167
  • Views 17049
Rotate PCB Layout
PCBWiz
PCBWiz over 5 years ago
           Orcad provides a flip layout feature in Display->Flip Design.
The flips from left to right or the other way around. So the flipping is done about the vertical axis.
Is there a top bottom flip too? I.e, can I flip around horizontal axis?
Where can I find it?
Thanks.
  • masamasa
    masamasa over 5 years ago
    what i usually do is to flip objects on the y axis and then to rotate them 180 degrees.
  • PCBWiz
    PCBWiz over 5 years ago in reply to masamasa
    Can you please let me know how to rotate 180 degrees?
  • masamasa
    masamasa over 5 years ago in reply to PCBWiz
    let us say we have the following objects.
    1. select them and copy them with snap pick to segment vertex
    2. on the right mouse button, click "mirror geometry"
    3 on the right mouse button, click "rotate"
    4. u can rotate the objects by moving the mouse
    5, once u rotate them 180 degrees, u paste them.
    6. u need to make sure that the rotation angle is set to whatever u desire. in my case i set 45 degrees
  • Micheal schenk
    Micheal schenk over 5 years ago in reply to masamasa
    masamasa very detailed explanation.
  • Lock2002
    Lock2002 over 5 years ago
    Just to be clear, you are not literally flipping the design. You are simply changing how you are viewing it. This has no bearing on the design output.
