  3. How to know what command is currently active ?
  • Views 12656
tennywhy
tennywhy over 5 years ago
Does anyone know how to get the currently running or active command?
Greatful
  • Daniel
    Daniel over 5 years ago
    You can try this : command > scriptmode +e
  • tennywhy
    tennywhy over 5 years ago in reply to Daniel
    Thank you for your reply,Yes, it is true that i can see the current command. How can I get this echoed status command in the skill code?
    I want to use the code to get the current active command, and then make judgments based on different situations
  • Daniel
    Daniel over 5 years ago in reply to tennywhy
    I think you should be using a script
  • tennywhy
    i want to get the current active command, script can do this ?  Please teach me how to do . thanks
