  3. Multilayer pad tricks?
  • Replies 9
  • Subscribers 167
  • Views 15545
beyondhelp
beyondhelp over 5 years ago
So in my quest of learning this software I've been sent a file with a large header. some of the pins require high currents between relatively small pins, I noticed between layers some of the through holes do not have pads around them. I've tried to play with the pad stack editor, but it seems I can't recreate this properly. I attached the following as an example. This is layer 3. Top row of pins have pads, bottom don't.
I shall continue playing, however if anyone has any advice I'd be grateful!
  • steve
    steve over 5 years ago +1
    Its probably the unused pad suppression that is driving this. watch Cadence PCB Dynamic Pad Suppression And Unused Pad Removal - YouTube
  • beyondhelp
    beyondhelp over 5 years ago in reply to Wild
    To answer that, I don't know. That would make sense however. Where should I find this?
  • TSCphil
    TSCphil over 5 years ago in reply to beyondhelp
    Look in the cross-section editor and make sure you have pins and/or vias checked for each layer.
  • TSCphil
    also make sure you have dynamic pad suppression turned on.
  • steve
    steve over 5 years ago in reply to beyondhelp
    There are a couple of property overrides for symbols and pins which may stop this. Try Edit - Properties (or Object Properties in OrCAD licenses) on the pins/symbols in question and see if they have a property unused_pads_ignore). The padstacks themselves also need to have allow suppression of unconnected internal pads enabled (so Tools - Padstack - Modify design padstack) select the pad and right click - Edit then look at the Options pane).
