  3. Multilayer pad tricks?
  • Replies 9
  • Subscribers 167
  • Views 15544
beyondhelp
beyondhelp over 5 years ago
So in my quest of learning this software I've been sent a file with a large header. some of the pins require high currents between relatively small pins, I noticed between layers some of the through holes do not have pads around them. I've tried to play with the pad stack editor, but it seems I can't recreate this properly. I attached the following as an example. This is layer 3. Top row of pins have pads, bottom don't.
I shall continue playing, however if anyone has any advice I'd be grateful!
  • steve
    steve over 5 years ago +1
    Its probably the unused pad suppression that is driving this. watch Cadence PCB Dynamic Pad Suppression And Unused Pad Removal - YouTube
  • steve
  • beyondhelp
    Thanks I'll have a look!
  • beyondhelp
    beyondhelp over 5 years ago in reply to steve
    Yes thats the answer! Looks a bit different in my version, but I've found it hidden away! Thanks!
  • beyondhelp
    Ok still fighting with this. Despite the options turned on, its not hiding pads, and looking and comparing to another file that does I can't yet see why.
  • Wild
    Wild over 5 years ago in reply to beyondhelp
    Are these shapes dynamic or static shapes? (need to be dynamic).
    Did you update the dynamic shapes?
