  3. Turn on/off visibility features in the active layer
  • Replies 10
  • Subscribers 166
  • Views 7154
Marw
Marw over 5 years ago
Hello All,
I am new user to cadence and I wanted to know how would write a script to turn on/off cond or via or pin..etc for the active layer using a bindkey?
    There's no tool called "Cadence" (that's the company name), so which tool and version are you talking about? I don't know what you mean by "turn on/off cond" means. or even turning on/off vias or pins…
  • Marw
    Marw over 5 years ago in reply to Andrew Beckett +1
    Hello Andrew, 1) I am using allegro SIP. 2) In the visibility column, you have Cond, via, pins, DRCs. each one of them is being represented as a box that you click on if you want to visually see…
    Andrew Beckett over 5 years ago in reply to Marw +1
    OK, so you're in completely the wrong forum. I'll move it to the right place (this is not related to Custom IC Design). Andrew
    If you clicked on the link in the email notification, you'd have seen it's now in the PCB Design Forum. I might have put it in the PCB SKILL Forum, but I wasn't certain whether this needed SKILL or not - I am leaving it to those who are familiar with Allegro SIP to determine that.
  • masamasa
    masamasa over 5 years ago in reply to Andrew Beckett
    if u would like pins and vias on top layer, u can use the following funckey:
    funckey 1 "QtSignal ColorVisibilityPane CVPGlobalVisOff clicked;QtSignal CVPLayerGrid CVPBoxAllTop clicked true; QtSignal CVPLayerGrid CVPButtonPlanTop clicked; QtSignal CVPLayerGrid CVPButtonDrcTop clicked; QtSignal CVPLayerGrid CVPButtonCondTop clicked"
    pressing the key "1" lets u only pins and vias visible on top layer.
  • Marw
    Marw over 5 years ago in reply to masamasa
    Hello masamasa,
    I thought of doing that before but the thing about the "CVPButtonPlanTop" that you have to specify the layer. Which means I am going to have so many funckeys. I wanted to change the "top" to the active layer. That way I only have few bindkeys instead of so many
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I have aliases defined in my env that might help you, shown below:
    alias alt     '(axlSetActiveLayer "etch/top")'
    alias alb     '(axlSetActiveLayer "etch/bottom")'
    alias vte     '((axlVisibleLayer "etch/top" t)(axlVisibleLayer "pin/top" t)(axlVisibleLayer "via class/top" t)(axlVisibleLayer "drc error class/top" t)(axlVisibleUpdate t))'
    alias vbe     '((axlVisibleLayer "etch/bottom" t)(axlVisibleLayer "pin/bottom" t)(axlVisibleLayer "via class/bottom" t)(axlVisibleLayer "drc error class/bottom" t)(axlVisibleUpdate t))'
  • Marw
    Marw over 5 years ago in reply to DavidJHutchins
    Hello David,
    Thank you. I just tested, it is not exactly what I am looking for. Sorry for not explaining myself well
    Lets say I defined a bindkey alt for the "Cond" in the visibility tab. if I click alt once it will make the cond visible and if I click alt again it will turn it off. In the case of the your alias that you provided, I am only able to turn it on but not off
    Also, I want to be to apply the same concept above in the active layer I am in. Not only for the top and bottom. If I apply the alias you provide it, I have to repeat it 16 time in my env for the 16 layers I have in the design.
    Hopefully this make sense
