  3. Turn on/off visibility features in the active layer
  • Replies 10
  • Subscribers 166
  • Views 7153
Marw
Marw over 5 years ago
Hello All,
I am new user to cadence and I wanted to know how would write a script to turn on/off cond or via or pin..etc for the active layer using a bindkey?
    There's no tool called "Cadence" (that's the company name), so which tool and version are you talking about? I don't know what you mean by "turn on/off cond" means. or even turning on/off vias or pins…
  • Marw
    Marw over 5 years ago in reply to Andrew Beckett +1
    Hello Andrew, 1) I am using allegro SIP. 2) In the visibility column, you have Cond, via, pins, DRCs. each one of them is being represented as a box that you click on if you want to visually see…
    Andrew Beckett over 5 years ago in reply to Marw +1
    OK, so you're in completely the wrong forum. I'll move it to the right place (this is not related to Custom IC Design). Andrew
    There's no tool called "Cadence" (that's the company name), so which tool and version are you talking about? I don't know what you mean by "turn on/off cond" means. or even turning on/off vias or pins for the active layer? Please clarify exactly what it is you're asking for...
  • Marw
    Hello Andrew,
    2) In the visibility column, you have Cond, via, pins, DRCs. each one of them is being represented as a box that you click on if you want to visually see in your design. So I mean by turn on/off is by clicking on the box. I want to make the click as a bindkey. I hope this make more sense
  • Marw
    Thanks Andrew
  • Marw
    to what forum are you moving it to? so I can keep track of it
