  3. How to add an external Package Length value to a net length...
  • Views 11787
How to add an external Package Length value to a net length constraint
TDuffy
TDuffy over 5 years ago
I am trying to set up pin pair length constraints in the Relative Prop Delay part of the Constraint Manager but I need to add an external Package Length value to the calculation.  There is an independent value for each net.
Is there a way to have the constraint mgr add that value to calculate the etch length for that net.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    look at the documentation for 'Schematic-driven Pin Delay Flow'
  • TDuffy
    TDuffy over 5 years ago in reply to DavidJHutchins
    That put me on the correct track to add that information in the Pin Delay property on the board.  Thank you for your help.
