  3. Cline Net Path Length Report
  • Views 13617
vimaldevlpr
vimaldevlpr over 5 years ago
I want to get cline reports using cadence skill but I don't know the command to get "NET PATH LENGTH" value any one please guide me to get the value I will attach my code below.
Code:
axlCmdRegister("net_len_kar_wid" 'net_len_kar_wid)
procedure(net_len_kar_wid()
originalVisible=axlVisibleGet()
axlVisibleDesign(t)
axlShell("redisplay")
axlClearSelSet()
axlSetFindFilter(?enabled '("NOALL", "CLINES"), ?onButtons "CLINES")
net_list = axlGetSelSet(axlAddSelectAll())
Net_rep = nil
foreach(net_data net_list
 Net_len = axlDBGetLength(net_data)
 Net_Path_len = ? ;I don't know the command to get
 Net_val = sprintf(nil, "%s,%s,%L,%L", net_data->net->name, net_data->layer, Net_len, ?)
 list_seg = nil
 foreach(net_data_seg net_data->segments
  Seg_width = net_data_seg->width
  when(Seg_width push(Seg_width list_seg))
 list_seg_unq = nil
 list_seg_unq = unique(list_seg)
 Final_val = sprintf(nil, "%s,%L", Net_val, list_seg_unq)
 when(Final_val push(Final_val Net_rep))
print(Net_rep)
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I think you only get the 'net path length' when the net is not completely connected,
    so per the comment in the documentation for axlDBGetLength:
         If a net is partially routed includes sum of all ratsnest manhatten lengths.
  • vimaldevlpr
    vimaldevlpr over 5 years ago in reply to DavidJHutchins
    Thanks a lot  David..
