  3. PCB Editor
  • Replies 8
  • Subscribers 166
  • Views 16426
PCB Editor
Davide98
Davide98 over 5 years ago
Hey all, I'm currently facing an error when trying to remove a Mechanical component in one of the boards I'm working on; indeed when I use the "Delete" command I get this error:
(SPMHDB-243): Cannot modify element; the object or a parent has the FIXED property. [help]
So I used the "Unfix" command making sure that all the Object Filter were flagged on and obviously the component and all the parts I can see are unfixed.
I even tried to see with F4 or the "Property" command but the component is unfixed.
What can I do?
Thanks to all!
  • steve
    steve over 5 years ago in reply to Davide98 +2
    Cracked it. Look at this Cannot move a component due to its FIXED property (cadence.com)
  • Davide98
    Davide98 over 5 years ago in reply to steve
    Nope, it doesn't work. I've attached the skinned version of the board; on the file there only are the two elements that give me the problem.
    Enjoy!
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/1106.Cadence-diagnostic.zip
  • steve
    • Vote Up +2 Vote Down
  • Davide98
    Yeah, now I can move the symbol; Thank you very much!
