  3. PCB Editor
  • Replies 8
  • Subscribers 166
  • Views 16425
PCB Editor
Davide98
Davide98 over 5 years ago
Hey all, I'm currently facing an error when trying to remove a Mechanical component in one of the boards I'm working on; indeed when I use the "Delete" command I get this error:
(SPMHDB-243): Cannot modify element; the object or a parent has the FIXED property. [help]
So I used the "Unfix" command making sure that all the Object Filter were flagged on and obviously the component and all the parts I can see are unfixed.
I even tried to see with F4 or the "Property" command but the component is unfixed.
What can I do?
Thanks to all!
  • steve
    steve over 5 years ago in reply to Davide98 +2
    Cracked it. Look at this Cannot move a component due to its FIXED property (cadence.com)
  • steve
    Any object type can be fixed so you may find that pin or symbol or component could have the fixed property. Try invoking the Unfix command then right click - Unfix All which does exactly that. You should then be able to delete the parts.
  • Davide98
    Davide98 over 5 years ago in reply to steve
    I didn't know this command, pretty useful! But it doesn't solve the problem, I always get the same message on the command window and I can't modify move or delete the object:
  • steve
    Ok Try a Tools - database Check (or Check - Database Check in OrCAD), check all the options and run the check then try again.
  • Davide98
    I've tried but I get the same error message
  • steve
    Ok make sure you are running the latest version of software 17.4-2019 S022 or 17.2-2016 S078 (maybe the version you are running had an issue). if that doesn't help you may need to send the board to Cadence/Channel Partner for them to investigate or zip it up and someone can take a look on the forum (if you are OK with that being public).
    Edit - I've had another thought, try opening the mechanical symbol and then unfix and right click unfix all (in the mechanical symbol). Then save, go back to the board and use Place - Update Symbols and refresh the symbol from the library. That may resolve the issue.
