  3. Snap to intersection using the function key, how to?
  • Views 12693
CadAce2K
CadAce2K over 5 years ago
I'm doing a bunch of shape edits and need to extend corners to 'construction line' intersections. Currently I edit the shape, select the vertex' and RMB 'Snap to Intersection'.
Is there a way to set that up with a function key (F2) so I can select the vertex ; hover over the intersection of lines ; and hit F2 to do the (RMB/Snap to Intersection) function?
Thanks in advance.
  • steve
    steve over 5 years ago in reply to CadAce2K +1
    You could also consider the Shape Application Mode which makes editing shapes much easier. Watch Cadence PCB Shape Edit Application Mode - YouTube
  • CadAce2K
    Oops, I should have searched first. (ht) Mike C  :   alias F2 "prepopup ; pop dyn_option_select 'Snap pick to@:@Intersection'"
  • steve
  • CadAce2K
    CadAce2K over 5 years ago in reply to steve
    Thank you. I'll have to get into this mode more often. Thx
