  3. PDF EXPORT
  • Subscribers 166
  • Views 14647
PDF EXPORT
vimaldevlpr
vimaldevlpr over 5 years ago
I want to export the every layers PDF. I used by below code its not working PDF is not generating any one please re correct the code or help me to get PDF by skill programing.
code:
 procedure(PDFEXP()
 l_cnvFiles = nil
    designName = axlCurrentDesign()
    foreach(filmName axlGetParam("artwork")->groupMembers
        f = strcat("PDF_" filmName)
        p = axlDMOpenFile("ALLEGRO_CNV" f "w")
        fprintf(p "#This is the Layer Conversion File used for\n")
        fprintf(p "#importing PDF data into Allegro/APD.\n\n")
        fprintf(p "#CLASS!SUBCLASS!PDF_LAYER!\n\n")
        foreach(layer axlGetParam(strcat("artwork:" filmName))->groupMembers
            layerStr = parseString(layer "/")
            fprintf(p "%s!\n%s!%s!\n\n" car(layerStr) cadr(layerStr) strcat(car(layerStr) "_" cadr(layerStr)))
        fprintf(p "#END\n")
        push(get_filename(p) l_cnvFiles)
        axlDMClose(p)
        sprintf(cmd "pdf_out -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/%s_%s.pdf\" %%s" f getWorkingDir() designName filmName)
        axlRunBatchDBProgram("Creating PDF File" cmd ?warnProgram t ?noExitMsgs t)
    errset(mapcar('deleteFile l_cnvFiles) t)
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    your cmd string has some errors, try the following:
    sprintf(cmd "pdf_out -$ %%s -c \"%s.cnv\" -o \"%s/%s_%s.pdf\" " f getWorkingDir() designName filmName)
  • vimaldevlpr
    vimaldevlpr over 5 years ago in reply to DavidJHutchins
    Hi david thanks for the reply how can i use this in lower license it shows me like below attached image.
    if not possible to get this method in lower end license means any other ways there. If it has means please guide me to do.
  • DavidJHutchins
    From a similar posting in 'PCB Design':
    Just as a FYI Export PDF is back again without a license. Available in 17.2-2016 S065 and 17.4-2019 S005.
  • Micheal schenk
    Micheal schenk over 4 years ago in reply to DavidJHutchins
    Instead of code, you can directly export PDF from PCB Canvas (provided you have installed the latest hotfix) with a few mouse clicks.
  • AvengerThanos
    AvengerThanos over 4 years ago
    Latest 17.4 has built-in PDF export for PCB which can also export each layer into PDF. This is much more convenient than skill.
