  3. Allegro 3D model not rendering in correct location
  • Views 15307
m0lts
m0lts over 4 years ago
I'm using Allegro PCB Venture to design a board and have loaded an stp file of a Harting DIN41612 connector.
I can orient it correctly in the 3D viewer but when I reload the 3D view the offsets and rotations are correct but the part is in the wrong place and orientation, see pic.
I have tried several stps of the same connector from different sources (non-identical files via size info) and they all do it, to the same location.
I have made it work for other similar connectors.
Any ideas? I'm running 2021.1 (17.4-2019 S021 [9/12/2021])
  • m0lts
    I have found that if I orient the connector upside down in place then the mapping loads properly. Could it be that the part is overhanging a virtual boundary?
  • m0lts
    Some more debugging - if I add the model as a separate mechanical part I get the same issue when I locate it in that area.
  • steve
    steve over 4 years ago in reply to m0lts
    Can you upload the connector dra and step files so we can take a closer look?
  • m0lts
    I can't make the upload work but here are the files on Google Drive. Both models do the same.
    The parts are delivered through CIS so I added the model via the 3d viewer in the PCB Editor as our admin is off sick at the moment.
    STEPS:
    https://drive.google.com/file/d/17je0W1_AnbzWLrAmy-Npq9dzC6mSkSev/view?usp=sharing
    https://drive.google.com/file/d/16RCm0jVoAm8gx9VDXsU6q0v0Dq8q_G1W/view?usp=sharing
    PSM:
    https://drive.google.com/file/d/1AQ7MeCZFdgFfp0xAL91I6s3rsa7N2ZX-/view?usp=sharing
    DRA:
    https://drive.google.com/file/d/1QTnIcz8qoPx0u-FaI3C3AMog-Ei8AWfS/view?usp=sharing
  • steve
    I see the same behaviour so you should send this to Cadence support/Channel Partner to take a closer look at this
