  3. outline enlargement
  • Views 11328
outline enlargement
masamasa
masamasa over 4 years ago
hello:
i am trying to enlarge the substrate size using the existing design file.
but i am getting an error saying "pick is outside the extent of the drawing."
can i make the substrate outline larger?
I have tried to change the x and y extents on the design parameter editor but it does not let me change it to a larger number.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    You may need to increase the Design Extents values for Left X and Lower Y and and also increase the Width and Height to allow the new outline to fit...
  • masamasa
    masamasa over 4 years ago in reply to DavidJHutchins
    thank you, david. i was able to enlarge the outline.
