  3. "net logic" question again
  • Views 2937
masamasa
masamasa over 4 years ago
hello
thanks to the skill code created by DavidJHutchins that lets me assign/change the net on multiple pins.
https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-design/50733/net-logic-question
(the forum does not let me reply to his comment for some unknown reasons but many thanks to david!)
now i would like to know how to deassign nets on multiple pins.
the net logic command lets you deassign a net on a single pin at a time.
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1
    Have you tried using the skill code & selecting the net name "Dummy Net"? This isn't exactly what you want since it changes the pins to the same "Dummy Net" instance, but it might be the easiest solution…
  • DavidJHutchins
    This isn't exactly what you want since it changes the pins to the same "Dummy Net" instance, but it might be the easiest solution...
  • masamasa
    masamasa over 4 years ago in reply to DavidJHutchins
    thank u, david. dummy net works. thank u again.
