  3. thermal relief connects settings
  • State Suggested Answer
  • Answers 1
  • Views 14575
myil17
myil17 over 4 years ago
I right clicked one of the pin and changed the dyn_thermal_con_type settings. I would like to to know if it's possible to assign different trace width to that specific pin without changing global or layer dynamic param setting.
I want to assign different thermal trace widths to different components on the same layer.
Regards
  • JuanCR
    JuanCR over 4 years ago in reply to mahimag +2 suggested
    Complementing mahimag's response: - Choose Edit -> Properties. - Select the Pins/Vias you want to modify - In the Edit Property window, select the Dyn_Fixed_Therm_Width_Array property and click on…
  • mahimag
    mahimag over 4 years ago +1
    Try " Dyn_Fixed_Therm_Width_Array" on individulal pin
  • mahimag
    0 mahimag over 4 years ago
    Try "Dyn_Fixed_Therm_Width_Array" on individulal pin
  • JuanCR
    0 JuanCR over 4 years ago in reply to mahimag
    - In the Edit Property window, select the Dyn_Fixed_Therm_Width_Array property and click on the Assign button.
    You can choose the value per layer.
    • Vote Up +2 Vote Down
  • myil17
    0 myil17 over 4 years ago in reply to JuanCR
    Thank you.
