  3. adding Calculiso correctly
  • Views 11537
myil17
myil17 over 4 years ago
Hi Everybody,
I am newbie on pcb design. I am working on a project which needs a Calculiso file to be included to pcb editor.
We are having a problem of adding this file correctly, no constrain is set when pcb editor is opened, into pcb editor.
Is it possible for somebody to show me how to add this file correctly so all the constrains are set when I open the pcb editor?
Regards
  • mahimag
    0 mahimag over 4 years ago
    what is the file format of your file? I have seen *.dcfx and *.tcfx files are used to import constraints in PCB Editor.
  • myil17
    0 myil17 over 4 years ago in reply to mahimag
    I only work on pcb side. I received a schematic folder and tried to synch it with layout by using export physical option. From schematic side, they said that the correct Calculiso file seems to be included, but for some reason it is not transferred correctly. So am i missing a step while trying to transfer it? It's an excel sheet.
    P.S : I am using EDM launcher.
