  3. how to enable net label in Cadence allegro (PCB editor ...
  • State Suggested Answer
  • Answers 2
  • Subscribers 166
  • Views 16906
how to enable net label in Cadence allegro (PCB editor )17.4 ??
kabalee
kabalee over 4 years ago
Hi everyone,
i tried to get net label for Pin/trace and shape in PCB venture license. even all the option are enabled
but i could not find label. can any one help for this post.
  • mahimag
    mahimag over 4 years ago +1 suggested
    sometimes custom color with global transparency combination can cause this, go to Display > Dehighlight and Dehighlight all with "retain object custom color " option disabled.
  • steve
    0 steve over 4 years ago
    Check to make sure that the Global Transparency isn't too high (Display - Color Visibility - Display tab). If this is set to 100% you won't see embedded nets names.
  • kabalee
    0 kabalee over 4 years ago in reply to steve
    Hi steve,
    i kept 20-50% . still i could not see the embedded nets in pin /shape/trace. is any other solution ??
  • mahimag
    0 mahimag over 4 years ago
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    Try renaming the pcbenv. This would work sometimes.
  • TiffanyB
    0 TiffanyB over 4 years ago
    I had the same problem working from my laptop. I was able to see net names after I redirected my primary display to an external monitor.
