  3. how to create group (make like same group ) in PCB editor...
  • Views 13326
how to create group (make like same group ) in PCB editor 17.4 ?
kabalee
kabalee over 4 years ago
Hi everyone,
In my design same circuit are repeated 20 times.
so I did placement replication, it is working well but shapes are create as static solid.to make correction need to do  disband the group each time
again need to assign as Group from Edit  ---> Group---> Need to assign Generic group for each circuit. so it is taking time as well as still some circuit to be add.
is any other option to create group (Group name :CKT1) like this group
  • steve
    steve over 4 years ago +1
    There are two new user preferences that were added as part of QIR3. Look at Setup - User Preferences - Placement - General and turn on disable_module_shape_convert and disable_module_no_lock which will…
  • steve
    0 steve over 4 years ago
    There are two new user preferences that were added as part of QIR3. Look at Setup - User Preferences - Placement - General and turn on disable_module_shape_convert and disable_module_no_lock which will revert the module creation back to the default way. For more info on this change look at Help - What's New and look under Module enhancements.
