  3. Measuring clearance in Allegro
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 12720
HAIO
HAIO over 4 years ago
Dear Team ,
I need to measure the distance(clearance) (that is shown in red line) using Allegro.May I know how to do it
Regards
HARI
  • steve
    0 steve over 4 years ago
    Try Display - Constraint (or Check - Constraints in OrCAD), then draw a window that crosses the pad and the copper pour. You see a report that lists the Constraints that are actually used and what they are set to.
  • jgregoire
    0 jgregoire over 4 years ago
    Use the Show Measure tool to measure between the pad and the shape. There will be an Air Gap value in the report that will represent the length of that red line.
