  3. thieving pads
  • State Suggested Answer
  • Replies 9
  • Answers 3
  • Views 16911
thieving pads
myil17
myil17 over 4 years ago
hi,
I am newbie in pcb design. I would like to implement thieving pads for some of the igbts. Can anybody help me? I don't know how to start with.
I was told the last pin of the igbt needs a thieving pad for wave soldering process. I share a picture where you can see how the thieving should replace.
Regards
  • SandeepVarrier
    SandeepVarrier over 4 years ago +1
    In Allegro PCB Editor, its present under the menu Route> Gloss>Parameters/Design/Room/Window/Highlighted/list, Here parameters are for making the settings rest are the option how user wish to execute the…
  • SandeepVarrier
    SandeepVarrier over 4 years ago in reply to myil17 +1 suggested
    After setting the parameters you can drag select the canvas if you wish to perform on multiple pins/nets if its individual pin you may click on the pins.
  • SandeepVarrier
    There are two types of Thieving, Copper Thieving and Solder Thieving, Copper thieving is used for Copper balancing in the PCB and Solder thieving comes handy in the reflow process of soldering where the…
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago in reply to myil17
    Teardrop follows the trace, by design.
  • myil17
    0 myil17 over 4 years ago in reply to SandeepVarrier
    I am informed by my team that there is not nothing to do with teardrops/filet and tapered trace. Basically it is enlarged pads in the bottom layer that will help to "catch" any excess solder paste so that solder shorts does not occur as easy. It will be applied to last pin of the component. have any idea how to implement that?
  • SandeepVarrier
    There are two types of Thieving, Copper Thieving and Solder Thieving, Copper thieving is used for Copper balancing in the PCB and Solder thieving comes handy in the reflow process of soldering where the last pad is provided with extra pad area or separate pad at the same distance to steal the excessive solder (placement also plays an important role generally odd angle placement is avoided). Some users provide fillet for better connectivity, manufacturability and re-solderability such that the traces don't have broken joints while rework.
    The first image you shared is of Fillet/teardrop in Allegro my response was in line to that.
    In your case if you wish to provide solder thieving pads you may provide the same in the footprint by providing extra pad with soldermask open.
  • myil17
    How can I create solder thieving in cadence? which menu should i use?
