  3. thieving pads
  • State Suggested Answer
  • Replies 9
  • Answers 3
  • Views 16910
thieving pads
myil17
myil17 over 4 years ago
hi,
I am newbie in pcb design. I would like to implement thieving pads for some of the igbts. Can anybody help me? I don't know how to start with.
I was told the last pin of the igbt needs a thieving pad for wave soldering process. I share a picture where you can see how the thieving should replace.
Regards
  • SandeepVarrier
    SandeepVarrier over 4 years ago +1
    In Allegro PCB Editor, its present under the menu Route> Gloss>Parameters/Design/Room/Window/Highlighted/list, Here parameters are for making the settings rest are the option how user wish to execute the…
  • SandeepVarrier
    SandeepVarrier over 4 years ago in reply to myil17 +1 suggested
    After setting the parameters you can drag select the canvas if you wish to perform on multiple pins/nets if its individual pin you may click on the pins.
  • SandeepVarrier
    There are two types of Thieving, Copper Thieving and Solder Thieving, Copper thieving is used for Copper balancing in the PCB and Solder thieving comes handy in the reflow process of soldering where the…
  • myil17
    0 myil17 over 4 years ago
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago
    In Allegro PCB Editor, its present under the menu Route> Gloss>Parameters/Design/Room/Window/Highlighted/list, Here parameters are for making the settings rest are the option how user wish to execute the command.
    Under parameters > Fillet and tapered trace is selected to make the required settings.
    In Allegro command window as well this can be executed type in
    add fillet
    Command uses current Glossing/Fillet parameters
  • myil17
    0 myil17 over 4 years ago in reply to SandeepVarrier
    How to apply this manually a selected pin? Is it possible to demonstrate it?
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago in reply to myil17
  • myil17
    Is it possible to change the direction of teardrops? It's through trace. Or should it normally be like that?
